ATV 3 - Trailers is unavailable - Try again later
•   our ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): 6.0.2 (6646.81.1)
•   The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.9
•   The device and operating system (including version number) that PlexConnect is installed on: iMac 13,1 – OS X 10.8.5 (12F45)
•   The local IP address of the device that PlexConnect is installed on: 192.168.0.6
•   The device and operating system (including version number) that the Plex media server (PMS) is installed on:  iMac 13,1 – OS X 10.8.5 (12F45)
•   The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.8.10
•   The local IP address of the device that the Plex media server (PMS) is installed on: 127.0.0.1:32400
•   The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. 1.2.22
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
logpath = .
enable_dnsserver = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = High
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
My log File: http://pastebin.com/ZZc13yGL
Morning, I’m receiving ‘Trailers is unavailable . Try again later.  I’ve spent hours reinstall, reconfiguring and I just cannot get it to load.  Please can you help?
•   The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.9  <------This ip should point to the ip Plexconnect server
•   The local IP address of the device that PlexConnect is installed on: 192.168.0.6 <----- Wich is this
Change DNS on the ATV to 192.168.0.6 should do the trick
Thank you for your prompt address.  Reference to ' The local IP address of the device that PlexConnect is installed on: 192.168.0.6' was a typo, it should be 192.168.0.9.  I'm still receiving the same error though.  Any ideas?
Try downloading and installing the latest version of Plexconnect from Baa’s github.
Thanks institute11, I've just redownloaded it from Baa's gitbut, but still the same error.
Please provide a new settings.cfg and log using the new install.
Thanks Institue11,
Here's the settings.cfg
[PlexConnect]
logpath = .
port_pms = 32400
port_webserver = 80
loglevel = High
port_ssl = 443
Here's the log:
Davids-iMac:PlexConnect-master-2 DavidSingleton$ sudo ./plexconnect.py
Password:
12:31:01 PlexConnect: ***
12:31:01 PlexConnect: PlexConnect
12:31:01 PlexConnect: Press CTRL-C to shut down.
12:31:01 PlexConnect: started: 12:31:01
12:31:01 PlexConnect: IP_self: 192.168.0.9
12:31:01 DNSServer: started: 12:31:01
12:31:01 DNSServer: ***
12:31:01 DNSServer: DNSServer: Serving DNS on 192.168.0.9 port 53.
12:31:01 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.9
12:31:01 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
12:31:01 DNSServer: forward other to higher level DNS: 8.8.8.8
12:31:01 WebServer: started: 12:31:01
12:31:01 WebServer: ***
12:31:01 WebServer: WebServer: Serving HTTP on 192.168.0.9 port 80.
12:31:01 WebServer: WebServer: Serving HTTPS on 192.168.0.9 port 443.
12:31:02 DNSServer: DNS request received!
12:31:02 DNSServer: Source: ('192.168.0.10', 54926)
12:31:02 DNSServer: Domain: www.icloud.com
12:31:02 DNSServer: ***forward request
12:31:02 DNSServer: -> DNS response from higher level
12:31:02 DNSServer: Source: ('192.168.0.10', 63791)
12:31:02 DNSServer: Domain: EVIntl-ocsp.verisign.com
12:31:08 DNSServer: DNS request received!
12:31:08 DNSServer: Source: ('192.168.0.10', 56229)
12:31:08 DNSServer: Domain: trailers.apple.com
12:31:08 DNSServer: ***intercept request
12:31:08 DNSServer: -> DNS response: 192.168.0.9
Ta
ur settings cfg feels wrong missing the line wich host to intercept.. sure u did a fresh install??
this is my cfg
[PlexConnect]
port_pms = 32400
port_webserver = 80
loglevel = Normal
logpath = .
hosttointercept = www.icloud.com    <----- this line is missing on yours
port_ssl = 443
enable_webserver_ssl = True
port_dnsserver = 53
The fastest solution opposed to troubleshooting is use the plexify app, It will generate everthing for you brand new, even the certs and walk you thru the entire installation automagically. If its still not working maybe you have a firewall or webserver or something else weird blocking ports. I would recommend deleting all the profiles from the atv and using the plexify generated cert on the atv. Restart router, mac, atv everything. Post results. You can use my signature or ibaa plexconnect wiki.
https://github.com/iBaa/PlexConnect/wiki/OSX-and-ATV-with-5.2-firmware-and-ethernet-internet-connection-installation-guide
https://forums.plexapp.com/index.php/topic/85156-plexify-os-x-application/
is the plexify app for windows or apple
I found it.....  For apple!!  that really sucks.
They are talking about making one for windows as well in the future.
that is good news but really sucks
yeah thats really the right way to get help.. <_<
Magic!... works a treat... Can't thank you enough :0)
