Accurate EPG for UK Freeview
Server Version#: 1.16.6.1592
Player Version#: All
Could you advise how I can get an EPG that doesn’t have lots of gaps and “ITV 1 Networking Programming”. Do I need to go to a 3rd Party source?
TIA
right now, yes - 3rd party sources are not perfect but way better.
J.
Thanks, could you advise which source is best for UK listings please?
SchedulesDirect is quite good (I am using it) but it doesn’t integrate directly with Plex. It costs $8 for 2 months or $24/year (I think).
You either need to use something like NextPVR (free) instead of Plex for your recordings or use a script to translate SchedulesDirect into XML for Plex to use.
I’m having the same issue! I thought that I was going mad as it use to be OK until a few days ago!
I’ve found http://www.xmltv.co.uk/feeds I’m not sure how accurate it is but going to give it a whirl
