Action Required: DVR Guide Change
In Dallas, TX love this setup.
I just got emailed from Plex that I need to uninstall and reinstall my DVR…
“Action Required: DVR Guide Change”
But do I really need to. I setup my Tuner and Synology Nas with Plex Server on December 10th 2020. Do I still need to reinstall it for the guide changes? Or when I installed on December 10th, was that already on the newer Guide?
Server Version#: 1.21.0.3711-b509cc236
Player Version#: 4.49.2
Tuner Make/Model: SiliconDust HDHomeRun HDHR5-4US Quatro 4
If that is the server version you started with then you should already be using Gracenote.
Methods of Verification
  1. Bottom of guide listing should say Powered by Gracenote
  2. Settings > Live TV & DVR Top should have () around channels DVR—Local Broadcast Listings (113 channels)
  3. In a browser got to https:\\app.plex.tv Settings > Console and filter on gracenote. You will need another client to look at TV shows . Should see metadata messages with gracenote in them.
Very interesting. Number 1 is a fail, but number 2 shows (126 channels).
Also, #3 didn’t work for me simply because I disabled the logs.
So is just the parentheses enough that I have Gracenote?
Check for guide data past the 15th, otherwise you would have to re-enable the logs and check.
Was able to scroll to Jan21 where I quit because my finger got tired of clicking!!!
