I found out Mel Brooks is not in the Plex database to make a smart collection from. Is there a way to add him? Thank you.
Do you have any movies with Mel Brooks in your library?
IIRC the advanced filter should let you filter for all occurrences while using the “plain actor filter” will only give you actors who are listed in the top-3 cast members in some movie.
That worked. Thank you.
