Add folders as a choice in advanced filters for creating smart playlist based on file location
I would like “folder” as an option in “advanced filter” so I can create a smart playlist based on file location.
This would be great as I have a lot of foreign films with incorrect language tags so when I filter for language there are missing movies and language cannot be manually edited in plex web.
As I have separated the movies into folders according to their language I can use folders view but it is cumbersome as it is list based and doesn’t display poster art.
I’ve seen other posts where people discuss changing incorrect language tags in files. Will try some of these when I have the time, but I think adding “folder” option to “advanced filter” would be useful. For example, people who create folder based libraries could combine libraries and use folder based smart playlists for creating homepage hubs.
There’s already an existing feature suggestion discussing an option to filter by paths or path segments (e.g. folders). I suggest you comment/vote in that thread in order to help us avoid distracting or cannibalizing votes.
Unless I’m missing some unique aspect of your suggestion I’ll close this thread as a duplicate.
2022 clean-up: duplicate
