I am trying to select multiple filters and can’t seem to figure it out. I want to be able to add let’s say Decade: 80s and also select Genre: Horror so I don’t have 300 movies to go through.
dane22
August 1, 2019, 4:40pm
2
Select custom filter, then something like:
Where do I find these settings? Can you access this through a TV or Mobile?
dane22
August 1, 2019, 4:54pm
4
WebClient
If you wanna use a player for it, I suggest you create a smart playlist instead
Please don't report problems in replies to How To posts. They don't get noticed. If you want to report a bug or ask a question, please post it in the appropriate forum, where it will have the best chance of being seen. Replies to How-Tos should be in reference to the article itself (typos, clarifications, etc.).
Creating Playlists
This article refers to Music playlists, but the instructions apply to Movie libraries as well. Photo playlists may be created as well, but some of the Selection pr…
Got it thanks! I’ll look into playlist as well.
system
Closed
October 30, 2019, 5:05pm
6
