Adding custom channel to Live TV
Hey!
i’m in the UK and i’m running an HDHomeRun twin tuner via Plex in a container on unRAID.
i’ve tied in an HDMI modulator to the aerial system feeding the HDHR so that my CCTV NVR [its not a networked one, its an older one] is broadcasting on its own TV channel and appears as one on the guide list.
it works absolutely fine, but i’ve got it tagged as a random TV channel. i’d like to be able to label the channel CCTV and not have the wrong TV guide info on it, is there any way to edit the guide to have my channel labelled on Live TV how i want it or am i stuck with it as is?
You need EPG assigned to the channel for it to show up in Plex. If you’re using the EPG provided by Plex then your answer is no. If you use your own XMLTV guide for all your channels then yes, it could be done.
