Adding media folders from Synology NAS running on NVIDIA Shield not working
Not sure where the correct place is to post this.
If it should be elsewhere, please point me in the right direction.
I have a new Synology DS218Play to add more storage to my media collection.
I already have 7 other Synology 2-bay NAS units.
All of which, I have setup fine previously.
However I have now hit a problem when trying to add the shared folders on the new unit.
The folder levels and naming conventions are identical to the other NAS units.
But, when I go to add an additional folder in Plex, it only sees the DISKSTATION drive, not the folders on it.
When I choose the other DISKSTATION drives I see a folder icon and all the sub-folders listed.
When I choose the new DISKSTATION drive I see a file icon and no folders listed.
I have checked that all the permissions and settings are the same as on the other units.
I can access the drive and all its contents using finder on macOS and file explorer on Windows 10.
2 pictures are attached.
DISKSTATION_7 - shows how everything as it should be.
DISKSTATION_8 - shows how only a file icon is showing.
So, I am unable to add my new media files to my Plex Library
My PlexMediaServer is running on a NVIDIA Shield.
All media content is stored on my Synology NAS units.
Any help appreciated.
Thanks.
I seem to be having the same issue. I can’t see any folders beyond the first Media folder. So I can’t select the Movie folder within my Media folder. Did you figure out a solution?
Hi. I’m having the same issue. In Control Panel, I set the permissions of the media folder (named video) I want to add to Plex library to ‘read/write’. But unfortunately that doesn’t help.
The only way I can add a folder to Plex library, is by moving this folder to the Plex shared folder on my Nas.
