Hello,
How can I add new cable operator for DVR. I mean frequency channel list (LCN)
symbol rate and other information ?
Ok i found the place. We need to add ini file at /usr/lib/plexmediaserver/Resources/Tuner/Shared/scanners/dvbc/transponders
For those who are using Telnet DVB-C Operator in Bulgaria you must do this under Linux:
- go to folder /usr/lib/plexmediaserver/Resources/Tuner/Shared/scanners/dvbc/transponders
- create file with name - 6666.ini
- put inside
[SATTYPE]
1=6666
2=DVB-C Bulgaria (Telnet, Veliko Tarnovo)
3=BG
[DVB]
0=20
1=442000,V,6875,QAM128
2=450000,V,6875,QAM128
3=458000,V,6875,QAM128
4=466000,V,6875,QAM128
5=583000,V,6875,QAM128
6=591000,V,6875,QAM128
7=599000,V,6875,QAM128
8=607000,V,6875,QAM128
9=615000,V,6875,QAM128
10=623000,V,6875,QAM128
11=631000,V,6875,QAM128
12=639.000,V,6875,QAM128
13=647000,V,6875,QAM128
14=655000,V,6875,QAM128
15=663000,V,6875,QAM128
16=671000,V,6875,QAM128
17=711000,V,6875,QAM128
18=719000,V,6875,QAM128
19=727000,V,6875,QAM128
20=735000,V,6875,QAM128
Now you can setup your DVR and choose Telnet / Bulgaria.
I tested this using Linux (gentoo) and Plex version 1.13.2.5154
My tuner although says not supported … works very well.
Its Technotrend USB Tunner
0b48:3012 TechnoTrend AG TT-connect CT2-4650 CI
If you need help contact me
Do you have the TechnoTrend AG TT-connect CT2-4650 CI working with encrypted channels using the CI slot?
Hello,
Yes i tested that before 1 year or more and they worked…
