Custom cable provider
Is there any way to define a custom cable provider in Plex? I need to specify frequency, symbol rate, modulation, network ID and so on. The current provider in my country is not listed when trying to configure the tuner.
Strange is that my provider is listed here:
https://www.plex.tv/features/live-tv-dvr/#remodal-channels
It is UPC in Romania.
But when trying to search using my TVButler and I choose Romania + Cable there is no mention of UPC or the other providers. And if I search I can find only 18 channels and no EPG for any of them so I cannot view any.
Thanks in advance for any help!
For Gracenote EPG issues report them here
I believe you can just make you own custom mappings.
To setup your own custom XMLTV file use using something like MC2XML try this
Thanks a lot for the answer. In the meantime I concluded that my issue is not with the EPG but with the parameters of the scan. If I choose Romania and Cable I can find only 18. Looking at the logs it is clear the search is done with wrong modulation and symbol rate. Is there any way to change those? Like defining a custom transponder file?
Found a temporary workaround for scanning UPC Romania channels.
Hop into /usr/lib/plexmediaserver/Resources/Tuner/Shared/scanners/dvbc/fast_scan/.
Duplicate the ./8007.ini file, edit the content to the following
[SATTYPE]
1=8027
2=DVB-C ROMANIA (UPC, Fast Scan)
3=RO
[DVB]
0=1
1=306000,V,6900,QAM256
The frequency Qam and modulation is taken from here: https://www.upc.ro/pdf/manuale/manual-upc-digitalcard.pdf
After scanning a network id choice menu will apear and from there just make sure to pick the ID corresponding to the location you’re scanning from.
If you’re using plex inside a docker container, watch the application logs if it can open the device.
Sep 16, 2018 17:22:37.772 [0x7efdb67fc700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Sep 16, 2018 17:22:37.772 [0x7efdb67fc700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Sep 16, 2018 17:22:37.772 [0x7efdb67fc700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter1/frontend0
These lines are esentually found here:
tail -f /config/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Tuner\ Service.*
I was getting error id 13 and i had to fiddle around with the permissions inside the container so that plex could actually read /dev/dvb (chown plex:plex /dev/dvb -R)
Hi There,
Can you please tell me what tunner are you using for scanning UPC Romania channels?
Thanks,
Seb
