Administration from mobile devices
  • manually fixing matches
  • scanning libraries
  • deleting items
  • create an optimised version
Dash is already in a good direction, it just needs to get more administrative features.
Scanning already exists in dash and I have seen fix match (automatically), but cannot find the latter anymore :smiley:
And auto fix match is kinda useless. If it would have matched the right one, then there was no need for fixing the match.
Edit: found fix match, only present in search mode (why?)
Edit2: it is not that useless, but manually inputting the parameters would be great.
Edit3: added optimisation
My personally, I would like to have the ability to share my connection with friends and family from my mobile phone (Android).
I would also like to be able to manage the user password/PIN and add and remove shared collections.
Also it would be great beeing able to edit sharing tags.
That’s already possible with the regular mobile Plex app (on Android at least).
What do you mean with “collections” in this case?
Came up with another one:
Edit a show/movies details, particularly age rating. Some shows do not have a rating on thetvdb and will then not show up for my managed kids user, whose content is restricted per age rating.
That’s expected, as the list is a “whitelist”. You wouldn’t want your kids to have access to an Unrated tv show by default.
What does this mean for this thread’s topic? Do you want to edit the show in question, to add a rating of your own?
Because you can already edit the user’s sharing permissions in the regular mobile app.
This.
I know that it works as intended and I am ok with that.
I didn’t know that! Thanks for the info :slight_smile:
I don’t understand the necessity for specifying particular settings, that is just over complicating it
Again, wouldn’t adding all of them be easier? Or asking too much?
Different people use different settings all the time. Example @Coxeroni wants to help better manage content for (I assume) his kids on mobile
I don’t have kids watching my plex server so that’s not relevant to likes of myself and many others, although I completely understand and agree with it. What’s the purpose of drilling down into specific settings rather than just not over complicating it with saying all the settings that are already present in plex Web?
Yep, performing the Plex Dance steps with one button push (other than moving the media in and out of Plex) is pretty cool (in Varys) but sadly I think is iOS only. Would be cool to see it in Plex Dash though.
What
I want to ask you guys something simple. When the video or audio is being transcoded the app shows the letters A and V in front of the movie. I wish the app showed the same detailed information as the expanded version of the web app.
Why:
Audio: Because some of my movies have 2.0 and 5.1 audios of the same language and my family sometimes text me complaining that the movies keep buffering (my NAS isn’t powerful enough to transcode in time). In this case, I could check if they were “watching” the 5.1 version and ask them to change to the 2.0 track. These information are also useful when you have movies with the original and dubbed audio and you want to check which one is being used.
Subtitles: basically the same idea. Some movies are dubbed but I still want to make sure the Forced subtitles are being used.
At this moment the only information I personally can extract from this app are:
  • Is anyone watching anything? yes/no
  • Is the movie being transcoded? yes/no
Other than that, the app has not much purpose.
Thank you
Where are you seeing this? Information on if something is being Transcoded should be on the Playback Info page.
I’m confused. There is no expanded version of Plex Web.
If the issue is the audio, then the video should not be transcoded. Transcoding audio is fairly low cpu intensive and your NAS should not have problems. If it can’t handle transcoding audio, you’ve got a really low powered device. If the video is transcoding, then there is something else going on.
Have you tried the new PlexDash app that was released recently.
Plex Dash:
Expanded Web Version
My suggestions are related to PlexDash development
It’s a bit misleading, but the Dashboard explains it:
The Video is being remuxed while the audio is being transcoded - in a Direct Steam. Technically that is a transcode, I guess.
The V could be VR (video remux)/Green V/Red V (not transcoding/transcoding) or something else clever so you’d know from Plexdash the full story.
Oh, then you’re off topic. This thread was referring to the current Plex for Android and iOS apps.
That’s part of the dashboard (for Plex Pass users), it’s not something different in Plex Web. Just want to make sure you get the terminology correct to avoid confusion.
You’re gonna need to be more specific about the types of activities you want to be able to perform.
  • Fix matches for poorly named files
  • Change posters or other metadata
  • Trigger library scans
  • Tweak server settings
  • Monitoring transcoding (e.g. figure out why it’s doing it at all)
I will say that having a more mobile-friendly skin on the existing server web interface would probably do the trick, but having some (particularly the metadata management) built into the mobile client with links off (e.g. for the server settings) to the full web interface would be amazing.
I will echo previous comments that I often want to fix something small and would prefer to not need a desktop browser.
Check out PlexDash https://www.plex.tv/plex-labs/.
these are some of the features that should be added to the app.
  • change metadata, sometimes when I add an ew movie to plex, it will not have a nice poster, and I have to go to the web app from my phone or go to my desk and on on my computer and make the changes, it would be nice if right from the app I can make the changes. I know plex dash you can do that, but I rather not have to switch apps or have multiple apps on my phone.
Ability to edit titles and other information on mobile
Can you add some basic server management functions to the mobile client, because it’s really uncomfortable to temporarily manage the plex server when you go out, and mobile browsers can’t display the plex server web pages very well. Can you add management functions to the mobile app?
+1 for this
 Chrome on iOS is unusable, but Safari works in a pinch. Would be much more convenient to use the mobile app :slight_smile:
