After Configuring 'Trailers' still load up Apple Default?
==ATV & Server Details==
ATV3G 5.1 (5201)
DNS: 192.168.0.203
PlexConnect on Windows Server 2008
(Server) Local IP Address: 192.168.0.203
Windows Server 2008
Plex Media Server Version 0.9.5.0-DC1DE23
PMS installed on 192.168.0.203
PlexConnect Version Number 0.1
Nothing Running over port 80 (IIS)
==Log Content==
22:51:26 PlexConnect: started: 22:51:26
22:51:26 PlexConnect: ***
22:51:26 PlexConnect: PlexConnect
22:51:26 PlexConnect: Press ENTER to shut down.
22:51:26 PlexConnect: IP_self: 192.168.0.203
22:51:26 PlexGDM: ***
22:51:26 PlexGDM: looking up Plex Media Server
22:51:27 PlexGDM: servers discovered: 1
22:51:27 PlexConnect: PMS: 192.168.0.203:32400
22:51:27 DNSServer: started: 22:51:27
22:51:27 DNSServer: ***
22:51:27 DNSServer: Starting up.
22:51:27 DNSServer: intercept trailers.apple.com: 192.168.0.203
22:51:27 DNSServer: forward other to higher level DNS: 8.8.8.8
22:51:27 WebServer: started: 22:51:27
22:51:28 WebServer: ***
22:51:28 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
(Here I pressed enter)
22:58:30 PlexConnect: Shutting down.
22:58:33 DNSServer: Shutting down.
22:58:33 WebServer: Shutting down.
==Issue==
When I click on Trailers it loads up the normal Apple trailers. It does not load up Plex.
Please can you help at all?
Jamie
Reboot the atv, sometimes the atv caches the DNS address and it won’t update until after a reboot.
Rebooted and still the same...
Your PMS version is very old, try updating that.
Updated PMS to 0.9.7 (The Latest Version)
Still no luck. Either says trailers are unavailable or they load up as normal?
What should the True IP PMS be? The IP of the PMS Server?
Which version of PlexConnect are you running? Because newer versions are shut down with Control-C not Enter. I think you're using a really old version of PlexConnect.
He is running v0.1.
He could try updating that too the latest source.
I updated to the latest version and still the same problem.
I know have to press Ctl C to Cancel. See logs below:
==Logs==
19:38:34 PlexConnect: started: 19:38:34
19:38:34 PlexConnect: ***
19:38:34 PlexConnect: PlexConnect
19:38:34 PlexConnect: Press CTRL-C to shut down.
19:38:34 PlexConnect: IP_self: 192.168.0.203
19:38:34 Settings: getsetting enable_dnsserver=True
19:38:35 DNSServer: started: 19:38:35
19:38:35 WebServer: started: 19:38:35
19:38:35 Settings: getsetting ip_dnsmaster=8.8.8.8
19:38:35 DNSServer: ***
19:38:35 DNSServer: Starting up.
19:38:36 DNSServer: intercept trailers.apple.com: 192.168.0.203
19:38:36 DNSServer: forward other to higher level DNS: 8.8.8.8
19:38:36 DNSServer: ***
19:38:36 Settings: getsetting ip_webserver=0.0.0.0
19:38:36 Settings: getsetting port_webserver=80
19:38:36 WebServer: ***
19:38:36 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
19:38:36 ATVSettings: init class CATVSettings
19:38:36 ATVSettings: load settings
19:38:36 Settings: getsetting enable_plexgdm=True
19:38:36 PlexGDM: ***
19:38:36 PlexGDM: looking up Plex Media Server
19:38:36 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
19:38:36 PlexGDM: Received data from ('192.168.0.203', 32414)
19:38:36 PlexGDM: Data received:
 HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: 074549c225223b6bdacea383d0f2838fe5c29725
Port: 32400
Updated-At: 1374488960
Version: 0.9.7.28-f80a4a2
19:38:37 PlexGDM: servers discovered: 1
19:38:37 PlexGDM: Server01 192.168.0.203:32400
19:38:37 XMLConverter: PlexGDM - PMS: 192.168.0.203:32400
19:39:14 PlexConnect: Shutting down.
19:39:14 Settings: getsetting enable_dnsserver=True
19:39:15 WebServer: Shutting down.
19:39:15 ATVSettings: save settings
19:39:16 DNSServer: Shutting down.
Can someone post working logs so I can compare?
Appreciate any help in advance
Ok under Windows Server you may need to create an inbound firewall rule for python.exe, you do have to on WHS 2011, but I'm not sure about Windows Server 2008. Give it a try anyway.
Thanks for the suggestion but I already created an inbound and outbound rule for Python.exe
Does anything else need to be aloud?
Also,  Why don't you update your AppleTV to 5.3?
Can you take screenshots of the rules, I have seen improperly created ones before that had the same symptoms.
Sure... Here are the firewall settings:
http://imgur.com/a/wnkrB
There is one exactly the same for Outbound too.
Updated ATV and still no luck. Any other suggestions?
Power cycle everything ATV pull plug for 10 seconds), PC and router.
Do you have any DNS entries in Windows or your router?
Do you have an third device with a web browser to help debugging? With PlexConnect running, try to direct the browser (smart phone, laptop) to your main machine (IP self): 192.168.0.203. Do you get an XML back? Or an Error? I guess, it should be error 403 - access denied or something.
With the same browser, what do you get back when accessing 192.168.0.203:32400? This should be the main PMS XML page... is this accessible?
So latest update i get this error.
==Error==
20:03:15 PlexConnect: started: 20:03:15
20:03:15 PlexConnect: ***
20:03:15 PlexConnect: PlexConnect
20:03:15 PlexConnect: Press CTRL-C to shut down.
20:03:15 PlexConnect: IP_self: 192.168.0.203
20:03:16 PlexConnect: started: 20:03:16
20:03:16 DNSServer: started: 20:03:16
20:03:16 WebServer: started: 20:03:16
20:03:16 DNSServer: ***
20:03:16 DNSServer: Starting up.
20:03:16 DNSServer: intercept trailers.apple.com: 192.168.0.203
20:03:16 DNSServer: forward other to higher level DNS: 8.8.8.8
20:03:16 WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 10013] An attempt was made to access a socket in a way forbidden by its access permissions
This is after I set this up.
http://forums.plexapp.com/index.php/topic/70321-running-with-local-dns-server-and-iis/
I was running IIS on here with the instructions but not a DNS Server...
I know its a very confusing set up.
In the end I have disabled both. IIS and DNS
==Summary==
-I have a Win2k8 Server running PMS (Version 0.9.7.28)
The IP of this server is 192.168.0.203
-I have created inbound and Outbound rule to allow Python.exe
-I have set my ATV's DNS to 192.168.0.203
-I then downloaded Python (version 2.7.5)
== Process ==
  1. I removed the power out of the ATV.
  2. Started Python.exe
I get the following logs:
20:20:43 PlexConnect: started: 20:20:43
20:20:43 PlexConnect: ***
20:20:43 PlexConnect: PlexConnect
20:20:43 PlexConnect: Press CTRL-C to shut down.
20:20:43 PlexConnect: IP_self: 192.168.0.203
20:20:43 DNSServer: started: 20:20:43
20:20:43 WebServer: started: 20:20:43
20:20:43 DNSServer: ***
20:20:43 DNSServer: Starting up.
20:20:43 DNSServer: intercept trailers.apple.com: 192.168.0.203
20:20:43 DNSServer: forward other to higher level DNS: 8.8.8.8
20:20:43 WebServer: ***
20:20:43 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:20:43 PlexGDM: ***
20:20:43 PlexGDM: looking up Plex Media Server
20:20:44 PlexGDM: servers discovered: 1
20:20:44 XMLConverter: PlexGDM - PMS: 192.168.0.203:32400
I then click on Trailers and it loads up the normal default apple trailers.
Sorry for all the posts and appreciate any help.
