Hi just updated plex player on all devices Mac , Pc and and two dots in folder view / list view are gone. I can’t go back up
Hitting esc key or whatever is “back” on your remote should take you up a level
You can click the “back” button (arrow) between the Plex icon and the search field.
nAH if You restart app it wont go back anywhere , it works like web browser back button.
So after restart app thinks you didn’t go to any folder but it loads in folder you been before restart and that back button dosen’t work.
