Cannot save settings on Agent page
Hi there,
I’m having a problem with Plex where I can’t save the settings on the Agent page. There is no “save changes” button and when I refresh the page it loads the default.
I found a reddit post where the guy suggested editing agent settings from the library, but I cannot enable opensubtitles.org that way.
I’m talking about this page:
https://support.plex.tv/articles/200241558-agents/
How can I save the settings in the agents page? Server version below.
Thanks,
Feriman
Server Version#: Plex Media Server v1.32.5.7349-8f4248874 - Docker Container (LinuxServer.io) aarch64 - build: linux-aarch64 debian - GMT 00:00
Player Version#: I open it in Web Browser
Agent settings are immediate.
No save is required unless you’re setting something which accepts a value
Solved.
I had to stop Plex in Docker, then remove the content of the folder below:
config/Library/Application Support/Plex Media Server/Cache
Then start Plex. Works as expected :slight_smile:
