All availabnle channels will not tune since moving to Linux
Server Version#: 4.63.0
Player Version#: 1.35.1.2632-c6783c78
Tuner Make/Model: Hauppauge 1609 WinTV-QuadHD PCI Express TV Tuner Card
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name:
I recently moved from a Windows 10 server to a Linux Mint 20.2 server. Since the move I am unable to scan all the available channels in my area (Toronto) There are about 40 and the most I have been able to get are 15. Even more mystifying is the local Toronto Channels are all missing.
Any advice would be welcome.
First thing to check, can you see them all (tune in) on the Hauppauge app in Mint?
If no see the Hauppauge site/search the web for Linux and your tuner.
If yes then in Plex (http://<my.ip.address>:32400/web):
Settings->MANAGE->Live TV & DVR
In CHANNEL SOURCES click on ‘xx enabled’
Here’s mine:
(I live in Mississauga and am using a Raspberry pi (Linux-Debian) with HDHomRun Quadro)
Are they enabled?
Did you try a RESCAN?
Hey, thanks for the reply. I’m confused, is there a Hauppauge app for Mint? I am not aware of one.
I have deleted and reinstalled the hardware a number of times.
I have also rescanned and enabled numerous times from the server, from the web interface, and from my windows client. All return the results that I indicated above. I did follow all the instructions from the Hauppauge site for my model. Interestingly I was told by their support team that it was unnecessary because the current Linux kernel supports my tuner “out of the box”
I am beginning to think that the hardware is damaged although I can’t see how but…
Sorry, I assumed they would have there own (or preferred) software.
So I posted this question Amazon.ca: Customer Questions & Answers?encoding=UTF8&sort=helpful&ref=pe_1139640_122623040_ans_notf_saa_aas
You said you moved from Win to Linux were the expected channels showing up in Windows? If you plug your antenna into you TV do you get the channels?
Thanks, As I suspected my existing card was damaged in some fashion as a new unit works perfectly. I appreciate the time you spent! Happy Thanksgiving!
