Hauppauge PCI Card no channels scanned
Server Version#: Windows 10 Pro - PLEX Version 1.19.5.3112
Tuner Make/Model: Hauppauge winTV-HVR-2255
Plex sees the tuner, but when scanning does not find any channels. I have removed/reinstalled the device multiple times, used the hcwclear utility from Hauppauge (does a complete de-install of any wintv stuff and drivers for the card), re-installed just the driver, all no difference.
The log has this after each scan:
Aug 13, 2020 13:59:22.049 [10476] INFO - [I] CTVSChannelScanner::Tune. Wait for lock timeout
Aug 13, 2020 13:59:22.049 [10476] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 3
Aug 13, 2020 13:59:22.049 [10476] INFO - [I] channel_scanner_t::scan_channels. Scanned 2 transponder out of 34. Channels found 0
Aug 13, 2020 13:59:22.098 [9944] INFO - [I] CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 4, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Aug 13, 2020 13:59:22.098 [9944] INFO - [I] SetTuner() 4, H, 0 Mod:0 LOF:0 22Khz:0
Aug 13, 2020 13:59:23.970 [6128] INFO - [I] web_service_t::process_device_status
Aug 13, 2020 13:59:23.970 [6128] INFO - [I] device_reactor_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_f1110070&rev_81#4&2683f545&0&00e4#)
Aug 13, 2020 13:59:23.970 [6128] INFO - [I] dvb_device_factory_t::get_device_list (dvb#bda#pci#ven_1131&dev_7164&subsys_f1110070&rev_81#4&2683f545&0&00e4#)
Aug 13, 2020 13:59:23.972 [5892] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Aug 13, 2020 13:59:23.972 [5892] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_f1110070&rev_81#4&2683f545&0&00e4#
Aug 13, 2020 13:59:23.973 [5892] INFO - [I] DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Aug 13, 2020 13:59:23.973 [5892] INFO - [I] DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_f1110070&rev_81#4&2683f545&0&00e4#
Aug 13, 2020 13:59:23.973 [5892] INFO - [I] DeviceGetListEx_impl: pDL->Count:2
Thanks!
