ALL DVR Recordings fail. Tried EVERYTHING
Please! The DVR function fails for ANY scheduled recording. This feature was working for months with no problem and then about 2 weeks ago started failing. I’ve done everything including, resetting the HDHomerun dual and making sure the firmware is current, Running setup on the HDHomerun again, Removing and setting up the DVR (HDHR) on Plex Server from scratch, removing all scheduled recordings and recreating them, tweaking all settings based on forum musts (HD vs SD, All vs New recordings etc), and finally I REBUILT the Plex install and entire database and libraries from scratch. After rebuilding, I added just 1 library to keep it simple for recordings to go into and added just a few scheduled recordings. ALL FAIL.
If I click on a show currently in progress in the program schedule and select record, it will record the remainder of the show. But nothing with scheduled recordings.
I see there are several others with similar issues.
Please HELP!
I’ve attached the entire log .zip below, but this one area seems to relate to a failed DVR recording…
Mar 11, 2019 11:00:00.433 [4100] ERROR - Unable to find title for item of type 5
Mar 11, 2019 11:00:00.433 [6856] ERROR - Unable to find title for item of type 5
Mar 11, 2019 11:00:25.622 [6856] ERROR - Failed to start session.
Mar 11, 2019 11:00:25.622 [4100] ERROR - Failed to start session.
Mar 11, 2019 11:00:25.622 [6856] ERROR - DVR:Recorder: Unable to create transcode session or session failed to start.
Mar 11, 2019 11:00:25.622 [4100] ERROR - DVR:Recorder: Unable to create transcode session or session failed to start.
Mar 11, 2019 11:00:25.622 [6856] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 11, 2019 11:00:25.622 [4100] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 11, 2019 11:00:25.639 [4100] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 11, 2019 11:00:25.639 [6856] ERROR - DVR:Recorder: Error 16 (Recording failed. Please check your tuner or antenna.) starting the record, shutting things down.
Mar 11, 2019 11:00:25.639 [6856] ERROR - DVR:Grabber: Starting media grab failed.
Mar 11, 2019 11:00:25.639 [4100] ERROR - DVR:Grabber: Starting media grab failed.
Plex Media Server Logs_2019-03-11_16-28-42.zip (442.7 KB)
