Server Version#: 1.13.6.5339
When trying to record shows using the DVR feature, the show does not record. Here is the log of when the recording is meant to start. Using a HDHomerun Connect.
Aug 27, 2018 19:30:00.405 [15696] DEBUG - DVR:Grabber: Starting operation for ‘The Block - E14 - Master Bedroom and Walk in Robe’.
Aug 27, 2018 19:30:00.405 [15696] DEBUG - Activity: registered new activity 047b1f4a-b83c-4a52-845c-f0e515464885 - Recording
Aug 27, 2018 19:30:00.406 [15696] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/123304E2 (Silicondust HDHomeRun CONNECT, supported) tuner 0.
Aug 27, 2018 19:30:00.406 [15696] DEBUG - DVR:Subscription: Resolved subscription to library item ‘The Block’ (43341)
Aug 27, 2018 19:30:00.407 [15696] DEBUG - There were 1 top-level paths for The Block.
Aug 27, 2018 19:30:00.407 [15696] DEBUG - DVR:Grabber: Saving recording to “U:\Recorded Shows.grab\0c39385eff2675703fdd1e0de967f87f3952c401”
Aug 27, 2018 19:30:01.182 [15696] DEBUG - HTTP requesting GET http://192.168.0.179:80/lineup.json
Aug 27, 2018 19:30:01.203 [15696] DEBUG - HTTP 200 response from GET http://192.168.0.179:80/lineup.json
Aug 27, 2018 19:30:01.203 [15696] DEBUG - DVR:Grabber: Going to record for 5099 seconds, final URL is http://192.168.0.179:5004/auto/v90
Aug 27, 2018 19:30:01.203 [15696] DEBUG - DVR:Grabber: Setting timer to stop grab of ‘The Block - E14 - Master Bedroom and Walk in Robe’ in 5099 seconds.
Aug 27, 2018 19:30:01.203 [15696] ERROR - DVR:Recorder: Error 0 (Success) starting the record, shutting things down.
Aug 27, 2018 19:30:01.203 [15696] DEBUG - MediaRecorderVirtual: setting stop time to 1535362201
Aug 27, 2018 19:30:01.203 [15696] DEBUG - DVR:Recorder: Stopping transcode session.
Aug 27, 2018 19:30:01.203 [15696] DEBUG - Job was already killed, not killing again.
Aug 27, 2018 19:30:01.204 [15696] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Aug 27, 2018 19:30:01.204 [15696] ERROR - DVR:Recorder: Error 0 (Success) starting the record, shutting things down.
Aug 27, 2018 19:30:01.204 [15696] DEBUG - MediaRecorderVirtual: setting stop time to 1535362201
Aug 27, 2018 19:30:01.204 [15696] DEBUG - DVR:Grabber: Operation for The Block - E14 - Master Bedroom and Walk in Robe completed with status error (Success)
Aug 27, 2018 19:30:01.204 [15696] DEBUG - Activity: Ended activity 047b1f4a-b83c-4a52-845c-f0e515464885.
Aug 27, 2018 19:30:01.204 [15696] ERROR - DVR:Grabber: Starting media grab failed.
