For the past couple of months, I’ve been unable to open certain TV shows from one of my Plex libraries on any iOS device, due to what looks like a bug in the recent major iOS update. I’d appreciate any help you can provide to help resolving the bug!
Note that I’ve manually redacted personally-identifiable information, replacing with REDACTED in log messages and error screens below.
Steps to reproduce:
- Open Plex on an iOS device (e.g. iPhone or iPad)
- Navigate to a specific library, grouped by “TV Shows”
- Navigate to a specific TV show in the library
Expected result: TV show loads as expected (showing which seasons are available).
Actual result: Spinner appears, and TV show never loads. I see the background poster but no seasons/episodes. After a few seconds, the following message is displayed:
Uh Oh… Something’s Not Right
Sorry, that didn’t work. Check that “REDACTED” is available and try again.
A “Retry” button is displayed, but selecting that triggers the same problem.
If I leave the iOS device on that same error screen for a minute or two, the screen is replaced by a new error screen with:
Sorry, that didn’t work. We are actively monitoring for issues. Try restarting the app or come back later.
This happens consistently across all of my iOS devices, but only for certain TV shows. All other TV shows load as expected. Out of 20 TV shows in the library, 6 of them exhibit this behaviour. Suspiciously (and unfortunately), the TV shows with the issue are also the ones that are used/watched most frequently. There’s nothing special about these specific TV shows vs other TV shows in this library or other libraries.
In addition, the “Recommended” tab always shows the same “Uh Oh” message. However, I don’t typically use the “Recommended” tab so that isn’t a specific problem for me.
As a workaround, I can switch the grouping from “TV Shows” to “Seasons” (or any other value like “Episodes”). When I do this, the individual seasons are selectable and I don’t encounter the problem.
The problem happens only on iOS devices, and only since the recent major update. Viewing via web browser and the Plex Apple TV app both work fine.
Checking the debug logs on the Plex media server itself doesn’t reveal anything useful. The following log lines are generated when I try to load a specific problematic TV show:
Jun 02, 2025 18:27:34.587 [140591485803320] Debug — Auth: authenticated user REDACTED as REDACTED
Jun 02, 2025 18:27:34.588 [140591288961848] Debug — Request: [REDACTED:49211 (Subnet)] GET /media/providers (4 live) #11d60 TLS GZIP Signed-in Token (REDACTED)
Jun 02, 2025 18:27:34.592 [140591288961848] Debug — [HCl#256f] HTTP requesting GET https://epg.provider.plex.tv?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Jun 02, 2025 18:27:34.614 [140591474383672] Debug — [HttpClient/HCl#256f] HTTP/2.0 (0.0s) 200 response from GET https://epg.provider.plex.tv?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (reused)
Jun 02, 2025 18:27:34.616 [140591487912760] Debug — Completed: [REDACTED:49211] 200 GET /media/providers (4 live) #11d60 TLS GZIP 28ms 6891 bytes (pipelined: 14)
Checking the logs exported from the iOS device, the following log lines were the only ones generated at the time of the above event:
06/02/2025 18:27:34:569 [REDACTED] DEBUG [Connections] Testing connection for REDACTED at https://REDACTED.plex.direct:32400
06/02/2025 18:27:34:575 [REDACTED] DEBUG [Connections] Testing connection for REDACTED at https://REDACTED.plex.direct:25573
06/02/2025 18:27:34:628 [REDACTED] DEBUG [Connections] Current best connection to REDACTED is https://REDACTED.plex.direct:32400
06/02/2025 18:27:44:576 [REDACTED] DEBUG [fetchJson] Fetch timeout: https://REDACTED.plex.direct:25573/media/providers
and:
2025/06/02 18:27:17.792 (2575241) ➖ (private) | check local network permission with timeout 1
2025/06/02 18:27:52.400 (2575934) ➖ (private) | check local network permission with timeout 1
I also tried reproducing the entire flow from clean app open to selecting the relevant TV show. When I loaded the library itself, prior to selecting a problematic TV show, I get these warning/error messages:
Jun 02, 2025 18:29:51.090 [140591295290168] Warning — [Req#11e63] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Jun 02, 2025 18:29:51.090 [140591295290168] Warning — [Req#11e63] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
Jun 02, 2025 18:30:02.026 [140591301618488] Error — [Req#11f05] Unknown metadata type: folder
Things I’ve tried that have not resolved the issue:
- On iOS device:
- Force-closing app
- Rebooting
- Uninstalling and reinstalling app
- Signing out of and back into Plex
- Switching user
- On server:
- Rebooting physical server
- Restarting Plex media server application
- Refreshing TV show metadata
Please let me know if you need any other info to debug. I’m happy to provide more detailed log files if you can give me a way to share them non-publicly.
Version info:
- Plex server version: 1.41.7.9823
- iOS app details:
- Client Version: 2025.17.0 (1082)
- Platform Version: 18.5
