This started a few weeks ago. All scheduled recordings are failing with above error. The DVR saves recordings to same location that my library points to…I can access my library fine. The recordings are saved to WD MyCloud NAS.
have you made any changes to the location? and did you / do you have library with multiple directory paths ? There were some recent fixes in this area
Best to get logs plus details of library selected and if it has more than one directory path (you can see that in Plex Web when you select edit library / add folders)
and which plex client is being used to setup the recording?
For logs see
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
