French trailers plugin : Dev start
I'm a working on my first plugin for Plex. It will add french trailers from the website Allocine.fr.
I will post here to annonce the releases
If you have features request, use this thread.
Bonjour,
Je développe mon premier plug-in pour Plex. Il donnera accès au bandes-annonces en francais du site Allocine.fr.
Je posterai ici pour annoncer les nouvelles versions
Si vous avez des idées à proposer utilisez ce sujet.
I post the first release of the plugin. There is a bundle and a site configuration file.
Please try it and give me your feedback
For people who doesn’t live in France tell me if you can watch the videos.
Feature requests are welcome :rolleyes:
EDITED : Attachement supressed see below to have a new version
Here is V0.2
Since the site have change the URL of the trailers the plugin was out of order
I update it and clean the code… It works.
Enjoy.
EDIT : Attachment suppressed since the V0.3 is out see the Wiki for last version
Since this morning I can’t use the Plugin. There is an error with the string file if you look at the logs
Can you tell me if you have the same problem ?
Hi here is the V0.3
This version should be mature
- I don’t use any more the siteConfig since I can have the flv file directly in HD
- I add the summary of the movie
- I don’t use the string file to avoid encode/decode issues since their is a Framework.bundle update
You can see the plugin with the following scrennshots :
http://img38.imageshack.us/img38/3636/principall.jpg
http://img40.imageshack.us/img40/9803/niveau1.jpg
http://img37.imageshack.us/img37/5361/niveau2.jpg
EDITED : Attachment suppressed. See the [Wiki](http://wiki.plexapp.com/index.php/Allociné)for last release
Thanks,
I try to have some new artwork made by an infographist. If the feedbacks are good the next release will be ready for the AppStore
Release of the the version 0.4 in the Wiki
It avoid crash when there is HTML tags in trailers description.
New version pushed on the App Store to fix crash due to the new website design.
Update you plugin with the App Store.
