According to the error, I think it has to do with the eac3 audio codec w/ Atmos metadata. I have DV/HDR10 files w/ TrueHD and they play fine. Files w/ standard eac3 5.1 audio plays fine as well.
Files w/ eac3 + Atmos fail to play on both my Pixel 9 Pro and Pixel Tablet.
This was an issue on the public app earlier this year:
It might just be the usual on containerized platforms:
the inability of the EAE binary to be executed in the /tmp folder of the container.
Which in turn is usually caused by either not being mapped at all (which would cause it to go into RAM),
or if it’s mapped, that this path (or the whole volume where it’s located) has been mounted with the NOEXEC parameter. Which will prevent execution of the EAE binary.
I get the same error. The content (HDR DV hybrid video with EAC3 Atmos audio in MKV container) plays fine in internal Android player non-preview version but fails in preview version (2024.12.1 1252). I do not use unraid, my PMS runs on Windows 2019 server with Plex Pass and hardware transcoding enabled.
Is it right that there is some client setting I can switch to make this work (by transcoding, I guess)? It seems I can’t find it. Shouldn’t that be automatic anyway, the error is very unclear for the average user?
