Pixel 9 Pro Can't Pay Dolby Digital Plus Atmos Content
This is a known issue on the main Plex app, but the workaround there is to go into settings and disable support for EAC3 (which still doesn’t really solve the issue as it forces a transcode, and requires users to really know what they’re doing).
See: https://forums.plex.tv/t/pixel-8-pro-repots-eac3-is-Supported-but-eac3-content-fails-to-play
I was hoping this would be fixed on the new app but it’s actually worse. The problem on the new app is that such a workaround doesn’t exist aside from disabling direct play/stream for all content!
This is what I’m greeted with when attempting to play EAC3 content with Atmos metadata present.
Look in Settings → Video & Audio.
On my Pixel 6a there are choices to enable/disable AC3/EAC3/TrueHD/DTS/DTS-HD.
I’m using build 2024.10.0 (1199).
Weird my settings are different. On the 2024.11.0 build.
My settings are the same as yours on version 2024.12.1.
Can anyone from Plex acknowledge this issue please? With the popularity of DD+ Atmos content this makes a lot of my media unplayable.
I’m experiencing the same issue on a Pixel 8 Pro and and a Pixel Tablet, quite frustrating. I was able to rectify this in the main app by disabling AC3 and EAC3 audio in the client settings, which apparently causes transcoding, but I don’t see those more advanced settings in the new Preview app.
I also dont have most of those options. On build 2024.13.0 (1261)
Any chance anyone from Plex can acknowledge these issues? I’m worried that this app is going to launch and be completely useless for a lot of Pixel owners. @BigWheel @RuudBurger
It is a sever issue which needs an update to ffmpeg. Ours is very customized which is why it is taking so long for the work on that update to finish.
Ok great, thank you for the update. Appreciate it’s taking a while due to the custom nature, but is there any ETA?
I’m sorry i do not have an ETA
Is there an ETA yet for this? At least to add back the client ability to disable eac3 and force transcoding? I still cannot play files with eac3 audio on my Pixel9 that work on all my other devices. Thanks!
I haven’t bumped this for a while because the new app now transcodes the eac3 audio so my files at least play.
Would be great to get an ETA on when a direct pay fix will happen though
Interesting, maybe I have a different issue. I am unable to play this type of file on my Pixel 9 with Plex 2025.23.0 but it plays on my Samsung S22, FireTV, and iPad. Trying to play produces just a black screen, never plays. Eventually times out with a “Error Occurred” “Source Error”. I have tried many files with this same codec format, always the same. Changing quality from “Original” to anything lower does not help. Appreciate if you have any ideas!
Video: 1080p HEVC Main 10
Audio: EAC3 5.1
The problem seems limited to certain Pixel models, as other models and other Android phones play EAC3 audio OK.
@BigWheel mentions earlier in the thread that the Plex Transcoder upgrade is a prerequisite.
The upgrade is currently a Forum Preview (pre-alpha): Transcoder Upgrade Forum Preview.
No info/dates/etc. are available for the transcoder update moving to beta/public status, the mobile apps getting an update, etc.
yes the server update for ffmpeg is needed but just running that forum preview will not fix things. There are other server things that need to be done afterwards then a client update when the server can tell it the difference between the two so it only transcodes the one with Atmos
