I read past threads saying the Echo client does not support FLAC. I have an Echo Studio, which is reported to support AAC, FLAC, MP3, Dolby Digital, Dolby Digital Plus, Opus & Vorbis.
Is it possible for the Plex server to support FLAC to Echo Studio w/o MP3 transcoding?
Streaming using Alexa. So the hardware supports FLAC, but the Alexa service does not?
What’s the highest fidelity way to play music from Plex server to Echo Studio? My options are:
Alexa service
Bluetooth from PC to Echo
Aux In
#3 is out because you lose Echo voice control except for volume as I understand. #2 seems a more compromised option than #1 .
What is the maximum MP3 bitrate Alexa will take? Can I configure Plex for it?
Thank you for the link. Interesting. Not updated since 2017. I hope Amazon’s venture into higher fidelity with the Studio cause more exposed capability.
The relevant section is “Audio Streaming Formats,” and not Audio Codecs. Right? If that is so, is there a way to stream AAC instead of MP3? How can I configure the max bitrate for AAC or MP3?
No. It could be changed in the skill but that would also result in MP3’s being converted to AAC. It basically sets the destination codec for all streams.
Plex should be using the highest setting of 256 kbps, unless your original has a lower bitrate. Plex does not increase the bitrate.
