No luck with new version ![]()
I had this issue. Did you check how much free hard drive space you have for your C:\Users\ winuser \AppData\Local\Plex Media Server . I found I had about 5 or 6 gigs left during the day on my solid state hard drive but found I was running out of disk space at night by looking through the Plex Media Server.3.log. Plex couldn’t communicate it to me other than through the logs.
Dec 20, 2017 09:18:26.004 [5136] DEBUG - Cleaning directory for session dbfc65c8-eced-4f87-99f9-fec4faba4993 ()
Dec 20, 2017 09:18:26.020 [5136] DEBUG - Starting a transcode session dbfc65c8-eced-4f87-99f9-fec4faba4993 at offset -1.0 (state=3)
Dec 20, 2017 09:18:26.020 [5136] DEBUG - Streaming Resource: Added session 12AC9680:dbfc65c8-eced-4f87-99f9-fec4faba4993
Dec 20, 2017 09:18:26.020 [5136] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Dec 20, 2017 09:18:26.020 [5136] DEBUG - TPU: hardware transcoding: final decoder: , final encoder:
Dec 20, 2017 09:18:26.020 [5136] WARN - Low disk space: 0B source file, 119.11GB capacity, 44kB available on C:\Users`winuser`\AppData\Local\Plex Media Server\Cache\Transcode\Sessions
Dec 20, 2017 09:18:26.020 [5136] WARN - TranscodeSession: inadequate disk space for transcode
Dec 20, 2017 09:18:26.020 [5136] DEBUG - Streaming Resource: Terminated session 12AC9680:dbfc65c8-eced-4f87-99f9-fec4faba4993 with reason Not enough disk space to convert this item.
Dec 20, 2017 09:18:26.020 [5136] ERROR - Failed to start session successfully.
Dec 20, 2017 09:18:26.020 [5136] ERROR - DVR:Recorder: Unable to create transcode session.
Dec 20, 2017 09:18:26.020 [2032] DEBUG - Killing job.
Dec 20, 2017 09:18:26.020 [5136] ERROR - DVR:Recorder: Error 14 (An unknown error occurred) starting the record, shutting things down.
Dec 20, 2017 09:18:26.020 [2032] DEBUG - Job was already killed, not killing again.
Dec 20, 2017 09:18:26.020 [5136] DEBUG - DVR:Grabber: Cleaning up rolling grab for channel 1003.
Dec 20, 2017 09:18:26.020 [2032] DEBUG - Stopping transcode session dbfc65c8-eced-4f87-99f9-fec4faba4993
I have a 256GB SSD as my OS drive with about 50GB free space still. Should that be enough to transcode with
3 tuners? I upgraded to a 3 TB drive for storage a couple of days ago because my 1 TB disk was filling up quickly. Both internal SATA 7200RPM
Are the logs you posted from yours or mine?
I did a search like this for all of the lines that read ERROR.
All lines with the string “ERROR” are in the file below
Well, I haven’t received this message in a while, I gave up on plex for a while and came back to see if this issue was gone. Although Young Sheldon is on channel 19-1 which I have duplicates and this may be part of the issue. I need to find out why plex records the 19-1 channel that is scrambled instead of the good one.
