Android App stuck on startup. Oxygen OS
I tested this in various other devices and server side is doing fine and the iPhone app works.
The android app is stuck on the logo at startup. I’ve cleared all local storage and cache. Uninstalled and reinstalled the app.
I’m stuck for more ideas.
Same here, for about a week with the beta version. I uninstalled it to try the normal version, but still suck at the plex logo
Which phone model do y’all have?
OnePlus 8T
Android 11
plex: 8.21.2.27212
I have the same specs/model as you
Is it the same OxygenOS build number as this user? Plex app not starting on Android device - #6 by Vashiru
Yes exactly, thank you to have pointed that out
As mentioned in the other topic, it started working on it’s own now. So I guess Plex got updated in the background :slight_smile:
I’ve the same problem on a OnePlus 8 and the last beta of the app.
app.plex.tv/desktop isn’t loading either altough I can use MYIP:32400 without any problem.
Nevermind, after trying to uninstall app, reinstall others versions, changing parameters on the server I restarted my phone and it’s now working. Both the app and the web.
