Android downloads fail
Server Version#: 1.24.4.5081 (NVidia Shield TV)
Player Version#: 8.25.1.28703
I am unable to download items using new Downloads. The download appears to get to 100%, but then it says the download failed and I should swipe to delete or tap to retry.
I am trying to download to an external SD card. After a failed download I cannot see any files in the /Android/data/com.plexapp.android/data folder, but I can see a bunch of empty numbered folders. I thought this might be an issue with a corrupt SD card but I replicated it with two different cards.
Logs.zip (536.9 KB)
See New Downloads Feature Keeps Failing (for files larger than 2GB).
That does look like the issue, the download files are getting chunked even though the SD Card is formatted with exFAT. I will await a fix.
