Android Player always crashes during playback of second song
Server Version#: 1.32.8.7639
Player Version#: 10.3.0.4685 (4ab0add)
Within the last couple of weeks I’m no longer able to play more than one complete song without the plex app locking up. I get the pop up that says “close app” or “wait”. Waiting does nothing, so closing the app is the only option.
Steps to reproduce:
  1. Open Plex app
  2. Navigate to Music Library
  3. Select shuffle to begin playing music
  4. Allow screen to lock
  5. Do not unlock phone
  6. Sometime in the middle of the second song the music will abruptly stop.
  7. Unlock phone and navigate to plex app
  8. Note that buttons are all completely unresponsive
  9. Note that media player still thinks its on the first song, even though the second song was playing.
  10. After some time a pop up will appear asking if you want to close the app.
I have attached the server logs and the player logs. Please let me know if there’s any additional info I can provide.
plex-log.zip (205.9 KB)
Plex Media Server Logs_2023-11-18_21-49-48.zip (4.6 MB)
Has anyone had a chance to look at this? It’s making Plex completely unusable for music for me, which is a real shame.
Is there any additional information I can upload?
I cannot reproduce this on my Android phone.
Is it possible that your phone is applying a particularly aggressive power saving method? i.e. apps which haven’t been used for time x are getting force-closed or stopped or deprived of cpu resources etc.
You should see the relevant settings in your phone’s Settings app, under Apps → Plex → “stop app if not used”, and/or Plex → Battery.
See if the behaviour changes if you select a less aggressive preference in there.
Do also verify that your phone is not permanently in “battery saving” mode. This will seriously interfere with apps which are not deemed “essential” by Android.
Hi @OttoKerner thank you for your response. I should have mentioned that I already thought that might be the issue. Plex is already set in “unrestricted” mode for battery usage, and power saving mode is not enabled.
