Server Version#: 1.24.4.5081
Player Version#:8.24.0.28408
suddenly my android client go crazy. let me explain
If i play a mp4 aac anime on android and goes direct play no problem.
if for any reason i trigger by myself automatic convert…it start play video at 2x speed…on every android device
No change both client and server side
Playing same file from edge on a pc client no problem.
The strange behaviour that tautulli show me is:
edge(pc) transcode h.264 to h.264 and aac to aac as expected
on android it says h.264 to h.264 and aac to OPUS wtf???
same issue here using PMS 1.24.5.5173 on OSX with playback on Shield 8.25.0.28665. My issue is only with recordings using the LiveTV function and using HDHomerun. Temporary fix is to optimise my recordings folder.
original file is h.264 4.0 audio aac
if i trigger automatic convert it start speed the video at x speed and on plyaback information i can see that the transcoding audio part is from aac to opus
which is strange because on 8.23.1 if i trigger auto convert is from aac to aac
plex doesn’t need really to convert aac… it’s only a test
This have to be fixed. it’s already 2 or 3 release of apk
it’s better if you temporary downgrade to 8.23.1 and stop automatic update in play store settings in the shield…until they fix. don’t worry. i’ll post an update when it works again. one of my android client is for test purpose only
