Android TV: Subtitle customization missing during playback
Server Version#: 1.43.4.10903
Player Version#: 2026.19.1
After updating to the new version with the redesign, the options to adjust the size and color of subtitles during playback are gone.
I was often adjusting both size and color while the movie was playing, because depending on the resolution and image properties of your file, there is no one size fits all setting.
Now you have to back out into the main menu and go through settings, which means you’re not even able to see how it looks during playback without going back to your movie, and then back to the settings again to tweak it further. This is extremely frustrating and I don’t understand why the options were removed.
I’ve also noticed that I lost the ability to adjust subtitle offset on most of my files. This wasn’t a problem before the redesign.
Please bring back the previous options. As it is now, Plex is borderline unusable for me and I’ve been using it since 2017.
