Anime With Symbols reading as the wrong show.
Hello,
I ran into a problem on a few shows im trying to add to my plex library. One of them is Working!!, My main problem with this is that the second season is called Working'!!, which is causing the first season not to show up at all. A Second Example is Yuru Yuri, The second season of it is called Yuru Yuri♪♪. The Music notes for me are causing it not to read both of the folders. I have tried making it its own folder and both being in the same folder. I am using BABS and the MAL Agent to scan my files, so i wonder if anyone knows of a fix for this.
The Problem with the Symbols is that plex can't display them, or at least while developing the MALAgent I didn't found a solution for this. The Problem with the mismatch with Working'!! is that the scanner removes some characters from the title and therefore isn't included in the search which results in only searching for Working!!.
In the case of Working!! you can "split" the Tv-Shows, (works only if 2 shows were merged because of the mismatch) there you will get both shows. Then you only need to do is to manually match the Show.
I'm sorry that I don't have any better news for this problem. But thank you for using my MALAgent :)
Thanks for the info!~ i might try messing around with some different scanners when the mal API is back up ^_^
Why not just name the shows as this for example:
Working!! --- this is the main dir
   - Season 1 --------- Season dir
   |        -  season 1 eps go here
    - Season 2 ---------- Second season dir
             -  season 2 eps go here
This is what i do with my anime and i have 150 different anime shows with all seasons named like this and have no problems with them in plex.
I just use the tvdb agent (the default) i think and have no problems with anime.
