Anybody having trouble adding Hustler?
I added the movie Hustler to my server, but it won’t show up. There are multiple movies with some iteration of hustle, including The Hustle, Hustlers, etc. which show up, but not hustler. This is a 2022 movie from Netflix. Even a search doesn’t reveal it. Any advice?
Do you mean the Adam Sandler movie Hustle?
Edit:
If you have a hard time matching a movie, you can include a reference from IMDb or The Movie Database in the movie’s folder name, e.g.
  • Hustle (2022) {tmdb-705861}
  • Hustle (2022) {imdb-tt8009428}
I had no problem with matching, only issue some of cast would be blank. I did not need to add the ID’s.
Note: after correcting naming you will need to do the Plex Dance
