Anyone else having issues with Match? Match / Fix Match not working for Albums for me.
Auto Match - I get “Spinning Wheel of Death”
Search Options finds the match, but selecting it does not add the match to the Album.
Server Version#: 1.26.1.5798
Seems to be working fine on my server.
Any errors showing in your server logs that might point to what’s causing this?
This is from Fix Match on an Album that was previously matched on the prior public server:
Here’s the server log error:
May 19, 2022 17:48:21.582 [0x7fb1248aa0] WARN - [HttpClient] HTTP error requesting GET Sign In | Plex (6, Couldn’t resolve host name) (Could not resolve host: plex.tv)
May 19, 2022 17:48:21.583 [0x7fb1287aa0] ERROR - [MediaProviderManager] Error parsing content.
May 19, 2022 17:48:21.588 [0x7fb1248aa0] WARN - [HttpClient] HTTP error requesting GET https://plex.tv/api/v2/server/access_tokens?auth_token=xxxxxxxxxxxxxxxxxxxx (6, Couldn’t resolve host name) (Could not resolve host: plex.tv)
And here’s what I get in matcher.log.
May 19, 2022 18:35:56.281 [0x7f7e5a3ab0] INFO - Plex Media Scanner v1.26.1.5798-99a4a6ac9 - Debian GNU/Linux PC aarch64 - build: linux-aarch64 - GMT -04:00
May 19, 2022 18:35:56.282 [0x7f7e5a3ab0] INFO - Linux version: 11 (bullseye), language: en-US
May 19, 2022 18:35:56.282 [0x7f7e5a3ab0] INFO - Processor: 4-core AArch64
May 19, 2022 18:35:56.282 [0x7f7e5a3ab0] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --match --type 8 --log-file-suffix Matcher --match-artist Neil Young --match-album Tonight’s the Night --files @/tmp/dd6a-93d6-26a3-1589.txt
May 19, 2022 18:35:56.558 [0x7f818b0890] ERROR - Match: Caught exception opening file: Could not parse /media/plex/Music/Neil Young/Tonight’s The Night (Vinyl)/01 - Tonight’s The Night.flac (error=-2): No such file or directory
Have you tried using a different DNS for your server?
It appears your current setup cannot resolve the domain plex.tv…
I use unbound, and as soon as I saw that error, I shut it down, and used 8,8,8.8. Same error.
Also, pinging plex.tv is OK:
pi@pi4:~ $ ping www.plex.tv
PING www.plex.tv (104.18.34.20) 56(84) bytes of data.
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=1 ttl=56 time=50.8 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=2 ttl=56 time=20.8 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=3 ttl=56 time=22.7 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=4 ttl=56 time=14.0 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=5 ttl=56 time=12.9 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=6 ttl=56 time=16.4 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=7 ttl=56 time=50.7 ms
64 bytes from 104.18.34.20 (104.18.34.20): icmp_seq=8 ttl=56 time=11.8 ms
curl reports:
pi@pi4:~ $ curl plex.tv
Moved Permanently
