Apple TV audio/subtitles settings over Plexconnect settings
Hello,
My config is:
  • Synology DS214 play
  • Apple TV 3
  • PMS : 0.9.12.19
  • Plexonnect: 0.5-12
When I use my iphone, Web app or other, when I set the audio or subtitles, everything works.
But on my Apple TV plexconnect don’t respect my choice of Subtitles or audio.
The Apple TV settings override those of plexconnect.
I don’t find some solution in the threads.
If you have any idea?
Thank you
It really isn’t that easy… I think PlexConnect tries to honor the setting, as long as it has the ability to do so - that is, if you have media/subtitle formats that don’t use the aTV native subtitle engine.
If you are using mp4/embedded subtitles however, everything on the player side is handled by iOS. And we haven’t found a way to override that behavior.
There might be other filetypes or situation where it doesn’t work as expected, but to figure that out we need more information: filetypes, codecs, subtitle format…
