Subtitles require transcoding?
Hello,
I have PlexConnect running on my Synology along with PMS. Everything works fine on the AppleTV except for subtitles.
If I try to play a movie with external subtitles I get an error. If I choose the same movie with no subtitles it plays fine.
My Synology is not able to do transcoding, I would expect that Apple TV would be able to render the subtitles on its side. But apparently it's trying to transcode everything together on the PMS side.
Is this normal? Isn't the Apple TV able to render the subs on its side?
Have a read of this thread https://forums.plex.tv/topic/95057-official-new-subtitle-renderer-feedback-thread/ the initial post has a link to the Subtitles supported direct via plexconnect.
External subs need to be SRT and in aTV settings you need to specify iOS, PMS in one of the parameters at the bottom
...or tell the type, come up with an import filter and I will happily add it into the Subtitle.py. :-D
I confirm that I have iOS, PMS on aTV settings and subtitles are SRT
Video
Codec H264
Bitrate 907 kbps
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Duration 2:08:14
Frame Rate 23.976 fps
Frame Rate Mode cfr
Has Scaling Matrix 0
Height 544
Level 4.1
Profile high
Ref Frames 4
Scan Type progressive
Width 1280
Audio
Codec AAC
Channels Stereo
Bitrate 94 kbps
Language English
Bitrate Mode VBR
Duration 2:08:14
Profile lc
Sampling Rate 48000 Hz
Subtitles
Codec SRT
Subtitles
Codec SRT
Language Português
Is there some way I can debug this on the PlexConnect side? I have checked plexconnect log and there's nothing there of note.
Maybe I can add some log statements in the Python code that deals with the subtitles (Subtitles.py) ?
With loglevel=High you should find one or the other log from Subtitles.py already.
Are your SRTs external to or embedded into the MKV files?
Are you using DirectPlay (transcoder in ATV Settings) ? It is a must for Synology ARM devices.
Ok have it set to High. Subtitles are external (automatically downloaded by the OpenSubtitles agent).
I had it on Auto because I have some shared libraries that do support transcoding. I no longer get the error when playing movies with subtitles, but _most_ of  the time I also don't see any subtitles.
Armed with my log files here's what I think is happening:
1 - Some automatically downloaded subtitles seem to missing a format.
WebServer: http request path:
/PMS(192.168.144.2)/library/streams/2019&PlexConnect=Subtitle&PlexConnectSubtitleFormat=&PlexConnectUDID=C07H9XNGDRHN
2 - There's also some encoding issues (at least in the log file):
20:33:10 Subtitle: ====== received Subtitle ======
20:33:10 Subtitle: 1
00:00:01,000 --> 00:00:04,074
Subtitles downloaded from www.OpenSubtitles.org
2
00:02:03,520 → 00:02:07,240
Bruxelas, B?lgica
3
00:02:27,280 → 00:02:29,320
CIA, Langley, Virginia
4
00:02:30,600 → 00:02:33,680
Opera??es Internac […]
20:33:10 Subtitle: ====== Subtitle finished ======
I'll have to learn where the OpenSubtitles agent stores its subtitles to further debug this.
PS: All of these subtitles work on Plex running on a RaspberryPi (http://www.rasplex.com).
I would love to know this as well. I've seen in another post that the Plex agent stores the subtitles as "metadata", therefore not in the same folder as the video file, consequently PlexConnect does not finds them. But I'm not 100% sure of this.
That's why I'm using Subliminal (from SynoCommunity) instead of Plex agents to search for subtitles.
Just realized that it would be great if on could set transcoding options per server instead of globally.
They are store in the "Media" folder along with the posters, etc. And PlexConnect does find them, they just don't work reliably.
I'll give that package you mentioned a try.
Great tip, thanks! I'm using this now and everything seems to be working. With the plus that subtitles are now stored next to the video file.
