Apple TV Purchased Library Hook Into Plex?
Wasn’t sure where to post this so starting in General Discussion. Specifically, I know the Search option in Plex can trawl your associated services (Netflix, Apple TV Store, HBO etc etc) BUT are there any plans / any way that your actual purchased Apple TV (Movies, TV shows etc) content can be found by Plex ? Therefore when searching for something like Batman that you may have purchased on Apple TV / iTunes, today Plex shows that you can buy on Apple TV, you click (using Apple TV 4K Hardware in this example) and it takes you to the Apple Store where of course it shows you can Play the title since you already purchased it BUT Plex it seems doesn’t know you purchased it inherently. Is it possible to do this or is something coming that will address this ? What I’m looking for is 1) at a bare minimum it would do like stuff it finds on HBO etc where it says, available on your services, you click and plays. Ideally the better option 2) would be that Plex in time would be able to allow you to add your purchased Apple TV / iTunes content into your library for a seamless experience.
Interested in hearing about these options from others and the Plex devs here.
Plex doesn’t currently have that option.
There’s a feature suggestion asking for an option to link items from the Discover feature to your libraries (e.g. directly pointing to a specific provider where you have purchased that item).
