Hi there, looking for some help as I can’t seem to resolve this one no matter what settings I play with..
AppleTV 4K 1st gen is trying to play it back. Latest Plexpass server installed on a Synology DS918+ (64-bit), and using latest app on AppleTV device.
This file plays back fine on a stereo setup LG C1 TV in another room (on the native Plex app on the LG platform). However, it plays back with distorted colours. Web player does the same.
Subtitles are not enabled, playback settings are to “play original quality”, full dynamic range, as you can see below it only has one audi o track, and subtitles are OFF.
When I play the file on the AppleTV 4K 1st gen, it plays the audio, but has a spinning disc. I tried enabled the video diagnostics but it won’t even display those. The appleTV reports this:
Source: Transcode (server name)
Quality 1920x1080 @ 12.5 Mbps
Video Copy (HEVC)
Audio Copy (EAC3)
Player AVPlayer
Transcode reason App cannot direct play this item. no direct play video profile exists for protocol http, with container mkv, and video codec hevc.
Tautulli tells me the following:
PRODUCT Plex for Apple TV
PLAYER Apple TV
QUALITY Original (6.0 Mbps)
STREAM Direct Stream
CONTAINER Converting (MKV MP4)
VIDEO Direct Stream (HEVC 1080p)
AUDIO Direct Stream (EAC3 5.1)
SUBTITLE None
The AppleTV itself is set to to “off” where it says 'auto adjust quality" - which seems to have fixed my reported symptoms for others when I’ve searched. I’ve enabled and disabled to ensure it’s set.
The file info is here:
Media
- Duration 53:07
- Bitrate 5323 kbps
- Width 1920
- Height 1080
- Aspect Ratio 1.78
- Video Resolution 1080p
- Container MKV
- Video Frame Rate 24p
- Video Profile main 10
Part
Duration 53:07
Show_WEB-DL.DDP5.1.DoVi.HEVC-NTb.mkv
Size 1.98 GB
Container MKV
Codec HEVC
Bitrate 5323 kbps
D O V I B L Present true
D O V I Level 3
D O V I Present true
D O V I Profile 5
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Location left
Chroma Subsampling 4:2:0
Coded Height 1080
Coded Width 1920
Color Range pc
Frame Rate 23.976 fps
Height 1080
Level 4.0
Profile main 10
Ref Frames 1
Width 1920
Display Title 1080p DoVi (HEVC Main 10)
Extended Display Title 1080p DoVi (HEVC Main 10)
Codec EAC3
Channels 6
Bitrate 640 kbps
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title English (EAC3 5.1)
Extended Display Title English (EAC3 5.1)
Codec SRT
Language English
Language Tag en
Display Title English (SRT)
Extended Display Title English (SRT)
Codec SRT
Language English
Language Tag en
Hearing Impaired true
Title SDH
Display Title English SDH (SRT)
Extended Display Title SDH (English SRT)
