Arabic Subtitle have been solved "Finally"
I found what it is wrong with arabic "or any other" sub title that not work in Plex. I trace log file and found the problem.....
1- plex only read UTF8 srt files.... so you have to be sure that srt file is UTF8 (you can easy convert that using notepad++ or any other tool you prefer)
![post-195919-0-32553500-1387921503.png|690x426](upload://jchbV1ZIElxeUFReIA7orMtHBRG.png)
2- remove any HTML code (ex  ) except () and any other thing like {\pos(195,110)}  (the easy way to do that in using reg exp as the following: \{[^\}]*\}|<[^>|i>]*> )
![post-195919-0-58378800-1387920799.png|690x381](upload://dUWwXXXbXfnuqH2V2M3B2roLFoZ.png)
3- add at the end of the file name (ara) before (.srt) (ex. Hours.2013.1080p.BluRay.x264.YIFY.srt => Hours.2013.1080p.BluRay.x264.YIFY.ara.srt)
that is all.... enjoy.
والي عنده 900 فلم تتوقع يبي يفتح كل فلم ويعمل هالموضوع ؟؟
كان الاجدر يحلون المشكله من الاساس حاله حال
xbmc
it is very important to know what the problem to be fixed... maybe some one how is good in python can fix that one and for all......
(بداية الغوث قطرة اخى الكريم)
for who is a developer... here is the first problem:
Dec 25, 2013 01:56:59:189 [0232] DEBUG - Content-Length of C:\Users\xxxxxxxxx\AppData\Local\Plex Media Server\Media/localhost/3/0732f2784d20c95f0f20f5cf57a50f002c44eb7.bundle/Contents/Subtitles/ar/com.plexapp.agents.opensubtitles_babcc62381348755cfb0a792e6bc8564109764bf.srt is 98164.
Dec 25, 2013 01:56:59:189 [0232] VERBOSE - Completed request: GET /library/streams/177: 200
Dec 25, 2013 01:56:59:189 [4872] VERBOSE - Finished writing response for GET /library/streams/177, 98164 bytes in 46ms
Dec 25, 2013 01:56:59:199 [14132] DEBUG - Detected character set of x-mac-cyrillic.
Dec 25, 2013 01:56:59:200 [14132] ERROR - Error opening conversion context from x-mac-cyrillic to utf-8
Dec 25, 2013 01:56:59:201 [14132] DEBUG - Wrote 0 bytes to C:\Users\xxxxxxx~1\AppData\Local\Temp\97c278a6-0db1-41b3-9951-852a9ecaed89.srt
Dec 25, 2013 01:56:59:201 [14132] DEBUG - Downloaded subtitles from [127.0.0.1:32400/library/streams/177] (format: srt) to temporary file [C:\Users\xxxxxxxxxx\AppData\Local\Temp\97c278a6-0db1-41b3-9951-852a9ecaed89.srt]
المشكله ansi srt
لازم تحولها لو تنحل ماتحتاج اي شي خلاص
Hi all,
I had same problem, and I fixed it, download subtitle edit
1,open the srt file in the editor.
2.change  format-encoding to UTF-8.
3.save the file.
4.rename the file to theMovieName.ara.srt
5.enjoy it.
Thanks alkhayyat this solved the problem it just needs editing with every video i add
WORKED FINALY After 14 hours trying!!!!
Here it is ;) some simple steps to convert multiple files via Notepad++ without messing up with special characters (for ex. diacritical marks).
  1. Run Notepad++ and then open menu Plugins->Plugin Manager->Show Plugin Manager
  2. Install Python Script. When plugin is installed, restart the application.
  3. Choose menu Plugins->Python Script->New script.
  4. Choose its name, and then past the following code:
convertToUTF8.py
import os;
import sys;
filePathSrc="C:\\Users\\" # Path to the folder with files to convert
for root, dirs, files in os.walk(filePathSrc):
for fn in files:
if fn[-4:] == '.xml': # Specify type of the files
notepad.open(root + "\\" + fn)
notepad.runMenuCommand("Encoding", "Convert to UTF-8")
notepad.save()
notepad.close()
After all, run the script
use Advanced Renamer to batch rename subtitle files
and use this tag :- .ar ;)
ياخي قلنالك مو حل كمثال خلي تحميل الترجمات من السيرفر بليكس opensubtitles
راح تنزل اغلبها ansi
بهالحال كل شوي عدل والى اخره
صراحه مهزلا كل هالوقت موقادرين يحلونها
Solution presented here is perfect, but unfortunately it is worling only if you are using plex web
But if you mux the subtitle with the movie in mkv file (internal subtitle)
The problem still exists!
I have still problem with arabic and persian language .
Ipad shows subtitle like this "م س ف ب ف ص ش ک".
    و حلت المشكلة  ولكن بعد القيام بتحديث البرنامج أصبحت الحروف متقطعة هل يوجد حل وشكراUTF 8 المشكلة أخي الكريم أني حولته  ل
ربما التحديث الجديد للبرنامج لا يدعم اللغة العربية
أنصح الجميع بعدم تحديث البرنامج حتى تحل هذه المشكلة
المشكلة أخي الكريم
المشكلة أخي الكريم
المشكلة بدأت بعد تحديث البرنامج لآخر إصدار
Me and other members tried to stop the release to the public for the current version until this issue is resolved but they didn't listen.
Any way if you want to solve the issue for the latest release follow the next steps:
  • Uninstall your current version of Plex
  • Install 0.9.914.531
  • Fetch the file DejaVuUniversal.ttf from the directory "C:\Program Files (x86)\Plex\Plex Media Server\Resources" (About 4 MB)
  • Uninstall Plex
  • Install the new version of Plex-Media-Server
  • Put the file in the same directory
  • You will notice that Plex uses a new font named PlexFont-Regular.ttf (About 9.9 MB)
  • Rename PlexFont-Regular.ttf to  PlexFont-Regular.ttfold
  • And rename DejaVuUniversal.ttf to PlexFont-Regular.ttf
  • Start Plex and Arabic characters will show as they should be.
Also a UTF-8 subtitle is a must whatever you do.
