Are the DVR recording details saved somewhere for easy restore
Server Version#: lastest
Player Version#: Lastest
For some unknown reason, I find myself having to rebuild my Plex Media Server about every 2 weeks. The scenario is always the same. Everything works fine until one day I’ll launch the app from NVIDIA and there will be a yellow triangle with an Exclamation point inside next to Live TV and each of my media libraries. Rebooting NVIDIA does not resolve this issue. The only solution I’ve found is to do a factory reset of the NVIDIA Shield and start from scratch. I’ve done this so many times now, It doesn’t take me long anymore. However, reconfiguring the DVR to record all my shows is a fairly time-consuming and tedious task. Is there a way I can back up this information and retore it after one of these events?
The DVR schedule is saved in your Plex database. Back this up and restore when you need to redo the server. You’ll need to move the Plex server data to an accessible storage location. The default internal storage is not user accessible.
