Artwork on my phone is other shows
Server Version#: 1.32.0.6950-8521b7d99
Player Version#: 9.20.1.979
for instance I have magnum pi. but the artwork is the show 9-1-1
how do i fix thisD
Is it only different on the phone app or also on other clients (e.g. the web app)?
If it’s generally off… is it just the artwork or also the rest of the metadata that’s off?
Could you give an example how your files are named and organized – and which folder from that organization is actually added/linked to the library?
also the web app. but it seems specific to series. the movies are picking up the right poster.
it seems to be a specific issue with series. i don’t if it is related to the structure i have for my series.
Movies are generally easier to name than TV shows. All you need is the name and date most times
Naming and folder structure for TV shows is a little more specific
Have a look over this support article
so i picked up from the readings i was starting one hierarchy further up then i should
so i wanted to do the vast world of tv shows in /videos/tv
whereas because under tv i have then done genre, /videos/tv/comedy i need to create it genre separately as an album. for example album “TV Shows Comedy” being /videos/tv/comedy and “TV Shows Drama” being /videos/tv/drama
