Server Version 1.23.2.4602
Player Version#: 7.18.1
Hello,
I have videos with 1360x688 This has a aspect ratio 16:8. On a 16:9 display it should show black bars above and below.
But instead it is zooming the video to 16:9. Is there a setting I can change this.
The post below applies to the nVidia Shield, but I think it’s the same on the ATV:
There’s a Display Mode setting that you may need to look at.
To get to it:
Start playing a video.
On the player control bar, go to the Action menu (far right)
[image]
Select ‘Playback Settings.’
Use the ‘Display Mode’ slider at the bottom of the list.
[image]
The setting persists, so it should apply to any video you play until you change it again.
Thanks for your answer.
But the apple tv app has no such a menu.
I got the menu on my shied, but any 21:9 video still gets stretched to 16:9 which is weird to look at. Any additional hints or settings I’m missing here?
system
Closed
November 16, 2021, 10:50am
5
