Hey everyone, new user here to. Mac and plex. Last night I installed plex on the aTV. Loaded a movie on the computer to test, worked like a charm. Was going through the “trailers” app on aTV to view plex library. Last night, perfect. Today I keep getting the error that says “trailers not available. Try again later” anyone seen this before? Any ideas to fix?
Is the plexconnect.py process still running?
Supports you provide all the details in the “read before posting” pinned thread, specifically in the how to report a problem, you will find a template of all required information to help us help you.
Supports you provide all the details in the "read before posting" pinned thread, specifically in the how to report a problem, you will find a template of all required information to help us help you.
How do I tell if the plexconnect.py is running? I'm sorry, absolutely new to Mac, I've just got my first mac last Thursday...Forgive my arrogance
Did you restart your mac before it stopped working? And if so, did you install PlexConnect as a service (so that it autostarts) or did you just runt the good 'ol sudo ./PlexConnect.py ?
The case might be as easy as you having to start up PlexConnect again :)
I have the same problem and on a second machine (friends computer where I installed Openplex too), appears the same error. I used iMovie instead the trailers app and suddenly it stopped working. I can't think of a reason and the log says it is running:
18:05:48 PlexConnect: started: 18:05:48
18:05:48 PlexConnect: Version: 0.3.1+
18:05:48 PlexConnect: Python: 2.7.5 (default, Mar 9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
18:05:48 PlexConnect: Host OS: darwin
18:05:48 PlexConnect: IP_self: 192.168.1.44
18:05:48 DNSServer: started: 18:05:48
18:05:48 DNSServer: ***
18:05:48 DNSServer: DNSServer: Serving DNS on 192.168.1.44 port 53.
18:05:49 WebServer: started: 18:05:49
18:05:49 WebServer: ***
18:05:49 WebServer: WebServer: Serving HTTP on 192.168.1.44 port 80.
18:05:49 WebServer: WebServer: Serving HTTPS on 192.168.1.44 port 443.
I now tried with the Trailers app and WSJ Live. Same problem on both...
certificate expired?
If this is the case, it should work with new certificates, right? I already tried to install new certificates, it didn't change a thing...
Also removed the old from aTV? Then installed the new ones?
From your earlier port: what is "suddenly"? Any new software installed? iOS update? Firewall on your computer?
The log can only help if it shows at least SOME aTV activity. ATV DNS correctly set to 192.168.1.44?
