Audio boost?
Does audio boos work for anyone else?
Changing audio boost within the player does absolutely nothing, I have tried on 3 different Android devices, xbox one, a Samsung smart tv, the web app. The audio level doesn’t change at all with any setting with everything i have tried… Starting to wonder why its even there…
Interesting question. Often wondered about this feature myself!
Audio boost is for 5.1 audio converted to 2 channel audio. The center channel (voice dialog) will be very low when it happens so you need to give it a little boost. If the source is 5.1 audio and your player output is 5.1 audio without converting it, you won’t hear anything different. Same thing if the source is 2 channel stereo and you’re listening to 2 channel stereo.
I found the “small” setting is enough of a boost to hear voice dialog. If I use large or huge, I will sometimes get static in the audio or the audio will sound worse.
Ahh, that totally makes sense now. Thank you @Joe4992
