I’m using Plex HTPC. I’m honestly perplexed why when I change that setting the app doesn’t keep it when I stop the playback and then resume it. Especially when it DOES keep the alteration when it comes to subtitle offset. Is there a way to solve this? If not, please fix it in future releases.
Just to clarify? Do you experience this behavior with audio offset changes during playback (e.g. using a keyboard shortcut) or based on the app-wide audio delay preferences?
I am not sure I fully understood the question but I think it’s the latter. Like, I start playing a movie on plex htpc and if there is an out of sync issue, I pause it, I go to audio offset setting and then fix it. If I resume playback after the pause, it’s fine. If I press stop (the screen goes to the movie info) and press play to resume it, the setting change has been lost and I have to do it all over again.
It’s just weird cause as I said if you do the same thing about subtitle offset the setting stands in case you press stop and then resume playback. The new timing is present, the change has taken place and not lost like the audio one.
