Fixed Audio Offset not working
Server Version#: 1.32.8.7639
Player Version#: 1.53.0.4063-cdc1f575
After changing my projector to an Optoma uhz65, the audio is always 275ms ahead.
When I set the delay after the movie is started from inside the playback settings it works.
But when I set the Fixed Audio Offset located in the Settings menu when playing a movie it doesn’t have any effect.
I have also tried change the setting in the mpv.conf file, located in C:\Users\HTPC\AppData\Local\Plex HTPC
Any ideas are appreciated.
Have you tried setting the delay for the 24Hz and 25Hz video as well?
That worked, thanks :+1:
If this is how it should work, I think the info text should be changed, it sounds like it is a general setting unless something else have been set in the other settings.
