So I normally use the Plex Kodi Addon with my Nvidia Shield as it can direct play “ASS” subtitles and the passthrough works best. Passthrough works perfectly and the reciever always shows the right format. Now I’ve had several problems with the addon and I’ve seen that its no longer maintained. So I want to use the normal plex app but audio Passthrough doesnt seem to work. I’ve enabled it in the settings (HDMI as its connect mted via hdmi)
When I start a stream my reciever only shows “mutli ch” and not the wanted audio format as for example dolby dts. Is this wanted or does passthrough just not work correctly?
I’m also having the same issue and have done for some time now and mainly when trying to play 4K content. Yet when playing 4K on Emby and Netflix etc all is working fine.
Its such a shame. With a good audio system you cant watch without passthrough, it destroys the viewing experience. Also the kodi addon isnt maintained anymore and full of other bugs. I dont want to quit plex… just such a shame
Shield Settings seem to fine as Kodi on the same machine is capable of it. On the Plex app there is only one setting to change and I did change it. I am also not the only one with this problem. In the end it doesnt matter that much as the shield can direct play most of my audio without passthrough. Still it does not seem to be my fault here or I am missing something
Yeah will try that. The HDMI cable is high quality tho.
Also is the handling of passthrough really that different (kodi vs plex) that the HDMI could be the problem with plex but not with kodi ? Will swap it anyway tho.
At least I havent seen any transcoding yet. And also the PCM Signal that gets passed to my reciever with plex shouldnt get me any quality loss I’ve read
After I tried some things and it didnt work I decided to factory reset my shield and do all over again, and now it works!
It may be that I missed something in the first place but more importanly it seems to work now. Thanks a ton mister
