I’ve registered for Beta Access via the Google form.
I have also noticed that started happening with the Auto Play issue was on some shows the Skip Credits box will not work, with the OK button, but will close with the Back/Return button and not advancing credits, this is still a issue
Did you lose all your app settings when changing to Test Flight app version? There is a prompt that could happen.
Been using the Test Flight app for years now without issues, all my current setting in the Plex app are the same as before.
Thanks for confirming, I shall proceed ![]()
I’ll take a look at this too. You can see I’m working on that functionality so I broke a thing or two.
Auto Play still broken on iOS/iPadOS/tvOS. When auto play is disable it still auto play.
You will need to update your tvOS to 8.36.1 to fix this (currently released on TestFlight) otherwise wait until Craig releases the update to the public via App Store, maybe 3 more sleeps.
I don’t know what you did Craig in the last update, but now I can back out of a episode when credits are playing and select next episode, I couldn’t do this before until the credits finished!! Good work…
