Pretty much as the title says haha. There is no settings or functions for the feature that was marked as implemented ![]()
What version of atv client? I’m on 8.39 (latest stable from app store) and it showed up about 20 hours after the announcement (6 days ago.)
I’m on the Testflight 8.40 beta hahaha
When the credits roll the up next screen does not automatically pop up and i dont have any settings for it, but all the other settings from the new player experience are available
I shall try the app store version to see if that makes a difference (but i doubt it will since i’m on the version after the release version)
In the iOS version, the settings are in a separate „Player Experience“ section just below the experience settings.
In the tvOS app (TestFlight version 8.40.9350), the player experience settings should be listed between the „video quality“ and „audio quality“ settings. I guess that’s a glitch and they’ll be moved to be in line with those in the iOS app.
Since a picture is worth 1000 words, heres are the settings i do have available:
As you can see, one of them is missing, specifically the one for this feature:
Next Episode / Autoplay During Ending Credits
I suppose it’s a combination of setting „skip credits“ to „automatically“ and „auto play countdown“ to „immediately“.
Autoplay countdown is for inside up next, the setting i’m referencing is to automatically show this screen when credits roll. It should not skip them, the video should keep playing in a smaller window and start a countdown to the next item, meaning this will be a separate setting haha
Would be nice to get a comment on if this will get added anytime soon, if not it might be worth re-opening the thread that was closed and incorrectly marked as implemented
