Automatic quality on, then i cant watch hd channels
On android it works…
I only hear the sound and it shows that its a 10 gbps stream..
When i turn it off and whatch tv it says 40mbps which i am sure is also wrong :wink:
Its on a new iphone 12 pro
Enabling automatic quality adjustment disables the experimental player, so you’re then unable to utilise the benefits it brings
Ok. I can live with it…
maybe you could make it clear in the app that it can case problems.
It had to figure it out myself.
