How do I disable the automatic scrolling on the home page on Plex Web 4.54.5, mouse over and the recently added videos scroll. Makes the home page useless. I tried to include a screen capture video of the scrolling but it was rejected because the extension is not for an image.
Which browser are you using? I’m not aware of any feature to do that. Is it when hovering over any part of the any row?
It is not a feature, it appears as though the mouse had issues. I switched out the mouse and now the “feature” is no longer an issue.
Update: After reading Noah0504 post I switched back to the original mouse and no scrolling issue has been encountered.
I’m actually seeing this as well.
EDIT: What appears to be happening is that it seems to remember your vertical position within a library. If you switch to another library and then back, it will “scroll” to your previous position. It looks like it’s only doing it on the recommended tab – the library tab works without issue.
Which browser are you using? The only way I can get the rows to scroll is hitting the arrows on the right of them
See my edit.
Apologies BigWheel, you asked and I didn’t respond about what browser I am using.
Google Chrome
Version 89.0.4389.114 (Official Build) (64-bit)
ah ok I thought was talking about the home screen rows scrolling horizontal through items.
@Noah0504 The library is only scrolling a slight bit up when go back to it not all the way to the place that I was but that is weird none the less. thanks for the details.
You’re right, it’s not scrolling to the original position. Screen resolution may affect the amount it does scroll, however.
Here are two quick screen captures. One is from my desktop computer with a larger screen resolution and the other is from my laptop with a 1366x768 resolution. You can see there appears to be much more screen movement on the laptop.
